fuse size
bigluis
the youngest member
i just finished hooking up a profile cl800 2 channel amp the current fuse in my distribution block blew it was a 50 amp fuse what amp fuse should i buy for this amp my friend was saying i needed a minimum amperage of 80
any help is greatly appreciated
yeah i have the proper size wire because i have less than three feet comming out of the distro and the amp is rated for 600 watts but ill guess ill give it a try with the 80 and hope for the best if not its time to upgrade wire and distro
I would check to make sure your wiring and everything is legit (battery connections, clean ground, etc.).
I ran a hifonics bx1500d @ 2 ohm on a 60 amp AGU (the glass kind) fuse without popping it, so i would think that profile amp should last on a 50 amp.
If anything, i would just pop a 60 amp fuse in there and see how it runs.
bigluis
the youngest member
bigluis
san pedro,ca
bigluis
BP1Fanatic
BP1Fanatic
