Fuse Size
I used these calculations to figure out the size of fuse I needed, but it still blew.
Gain Setting:
Sqrt(1800 watts *1 ohm) = 42.3 volts
Fuse Size:
1800 watts/ 42.3 volts = 42.3 amps
I set my gain around 40-50 volts (The knob was maybe turned up a quarter). I then hooked up the speakers and played it for about 15 minutes and blew a 60amp fuse. Did I do something wrong? How come i hit 42.3 volts at a quarter of the way up on my amp? Shouldn't this be a little over 50% turned on a 3000 watt amp?
I went to a local store and found a 100 amp fuse. I am going to try this tonight. It would be a bad idea to raise the gain any higher than 42.3 volts right? My two subs are 900 watts rms, so 1800 watts should be perfect. Just a little confused on why the gain is so low but my volts are so high...
Can anyone clear this up for me?
Thanks
Gain is dependent on the voltage of the signal coming from the HU. 1/4 gain would be about as expected if you're using a fairly high voltage source.
What HU are you using?
To approximate fuse size you want to use the voltage of the power supply (12-14) not the voltage out of the amp's speaker output.
1800w/14v = 128A.
That would be test tone power requirements. 100A should work well for you.
I have a hifonics bx1800d amp thats 3000 watts peak and 1800 watts rms. I am trying to run 1800 @ 1ohm. I have 4 gauge wire with a 60 amp fuse. I keep blowing my fuse. How big of a fuse do I need for this?
how much protection is on the AMP!? it's probably around 180 amps
the amp has protection from over powering it, fuses.
YOU fuse the WIRE rating. there's a chart on a few places including http://www.bcae1.com
btw, the AGC glass tube fuses only go to 80 amps.
Gain is dependent on the voltage of the signal coming from the HU. 1/4 gain would be about as expected if you're using a fairly high voltage source.What HU are you using?
1800w/14v = 128A.
I have the kenwood kdc-mp828 HU with 5.0V preout. Should I take my 100a fuse back and get the 150a fuse?
I bought a different fuse holder so I can fit big fuses.
Now that I think about it, I had the 0-18db knob turned to 0 on the amp, but had a remote knob that was turned up to 18db. When I turned it down to 0db the fuse popped. I should leave the db level on my amp at 0 right?
The latest...
Last night I hooked up my 150A fuse. Then I played a 50hz test tone and tried set the gain on my amp. I turned the gain all the way up and the highest reading I got was like 20.1 volts. I was looking for 42.3 volts. I then decided to put in a music CD and set the gain this way. After this, everything is working great. Something I noticed was that my lows are lower than i desire (sounds like the lows stretch out longer than they should in the song) or used to. I have my Low pass(35hz-250hz) turned up a quarter of the way and I am guessing I have this set to low for the sound I am looking for. I also think that my Low pass was too high/too low (not sure) and my 50hz freq was being ignored by the amp. Does this sound right? Was my Low pass to high or to low? If I want a more dominant bass sound instead of a low long lasting bass sound, what do I need to adjust?
Thanks
grtn316
grtn316
Midland
djman37
michigan born
    May 14, 2026
michigan born
    May 14, 2026
