Fuse rating vs. RMS question
at 12v, you can calculate the approximate max (clean) rms by multiplying 12*fuse rating. So an amp with a 10a fuse would give you 120 watts @ 12v. Now consider that it is likely 80% efficient or so depending on what kind of amp/quality/etc...and you end up with a little under 100 watts.
Yes, guessing that an amp will do 10 times it's fuse rating in power is generally a good estimate. You will not find an amp that needs a 50 amp fuse making 1000 watts at 12-14v without serious distortion and blowing that fuse if not damaging the amp
the amps ive seen. my aq 2200d was 200a my 3250 is 300a. someone posted a jl 1000/1 and said the manual said 100a. so yeh its seems that its about 10a per 100w.
If you are referring to the Slash series from JL Audio, then you are wrong. It doesn't have fuses.
totally wrong there is plenty of amps out there that have 2 40 amp fuses and are rated @1200rms and do 1400ish clamped. reason it takes 200% of fuse rating to blow over a 3sec period.
true but i bet its not clean power.
and your saying that an 80a fuse will need to see 240a for 3 seconds to blow?//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Fuse rating also depends on if your amp is High Voltage/High Impedance versus High Current/Low Impedance. I have an amp that does 400 watts RMS @ 8 ohms with a tiny *** 25 amp fuse! Of course the rail voltages inside of that amplifier are high enough to pack a serious wallop to them!
BamBam28
BamBam28
AL
SPLaudio
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
