Fuse Keeps Blowing
I have an AGU 60 amp fuse, I have 2 sa 12s running on a hifonics brutus 2100.1D amp. Do I need to get a bigger fuse? In the last 3 days ive blown 2 fuses. Also they dont blow right away only if I turn it up to loud.
you need to upgrade your wire to 0/1 asap, or puff the magic smoke if your lucky if not lucky, new car. atleast 250a fuse on that 0/1. i have a saz1500 rated for 150a but went ahead a placed a 200a fuse to be just to be on the safe side. seriously, change your wire, power/ground for that amp.
Sounds like a bad ground or wiring problem on the 12v+ side.
13
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
739
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
667
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
Athletestar123
Athletestar123
South Carolina
nu2spl
