fuse holder required?
No prob sizz, but if you want to buy a better one thats up to you..I'm just using a audiopipe holder to mine w/ a 140a fuse and its fine. My amp is only rated to 120a iirc..
Dont know if you answered this allready but are you running 1 or 2 amps? From what i read only 1..If you plan on getting another amp for the insides get a distroblock that is 0/1-2ga in and 2 2ga or 4ga out..Most amps will only beable to fit 4ga in them..Unless you have a huge amp..I know my mtx 1501d (1500rms), kicker 800.2(900rms), ap2400d(1500rms) all had 4ga power inputs.
Yeah I'm only gonna be running 1 amp. Ill show you what I mean with the distro block...at least I think its a distro block.
So yeah i mean...I'm clueless as to if I will even need this, or if this is even a distro block.
hmmm, i suprised nobody has asked this.
Ha yeah sorry here's the amp I have.
hell you'd be fine w/8ga on that amp..But i'd run bigger if you plan on upgrading.
And yea thats a distroblock..You'd be fine running that by your battery if ya aint got nuthin else.Just make sure water and stuff cant get to it..
Im lookin to wire up some 2g wire to my 1000 watt amp...I have my old fuse holder from my 10g wiring setup. will that work? and do i even need one?
Im disapointed in my fellow Minnesotan....
YES ONE IS NEEDED //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Guy i new burned his GTP to the ground for not having a fuse.... No fuse + NOZ Bazooka tube = Fiery Death
sizzl3r
sizzl3r
Minnesota
miker
