I just had my system installed and noticed there is only one fuse block (400a) and it's located under the hood about 6 inches from the battery. That 2/0 is going to the rear to my 2nd battery. There is no other fuses used. I know I need one going to each amp and each battery. But I have read some people use a fuse 6 inches from each battery so I should have 2 on each power wire between batteries correct? Or is that overkill? I think the 400a is overkill as well. Videos I have seen on YouTube suggest 200a.
Also I bought dual inputs for my Taramp 8000d which requires 360a fuse. If I fuse each power wire going into the dual input I would divide that in half correct? So about 180 or 200a per input for a total of 360-400.
