fuse big 3 wire yes or no
yes. its not worth risking your car/truck over man //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i remember seeing pics of one members rise after it burned. would **** to be you.
If you believe your install of the big 3 will have no flaws ever. Then by all means don't put a fuse. But if you think even a little, there could be an accident somehow, somewere, then put a fuse. It's cheap insurance.
yes i do drive a king ranch had mobeious build a box to fit inplace of the rear console for my subs did a gret job btw
so as long as i dont mess up with my wiring on the big 3 then it shouldnt be a problem right
stock doesnt have fuse does it
Stock is fused through the fuse box. If I were you I would definitely fuse it. One loose crimp or connection and you could be kissing your car good-bye. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes, fuse it. I could have lost my car over it after I had my HO alt put in. The guy who put it in ran my power wire across the serpentine belt for some reason. about a day or so later my car decides to shut down
I have upgraded the power wire from the alt to the battery in 3 cars and never fused that wire.
However, I will never do something that stupid again, anything could have happen.
Like it was mention above its cheap insurance for the system as well as the car. Fuse it.
Not in my Jeep, alt--->batt is a straight 8 ga run from the factory.
king ranch
Banned
king ranch
fl
SPL Blazer
