FS: Power Acoustic BAMF 4000/1D
dross93ranger
This amp is in great shape, it is less than a year old and works like a brand new amp. The bass knob is also included, but not pictured. 9/10 Cosmetic (some minor scuffs on the heat sync) and 10/10 mechanical. The bass knob has a blue LED.
$180 OBO Will also do partial trades (An EQ, 4/2 Channel Amp, Offer anything and how much cash you would give) + cash, but I must get ATLEAST $100 with any trade.
4000W Max Monoblock Class D Amplifier Car Amplifier
RMS Power Rating:
4 ohms: 1200 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2200 watts x 1 chan.
Max power output: 4000 watts x 1 chan.
Fully regulated PWM power supply
Wired remote bass level control included
System distress indicator
Four way protection circuit
Adjustable Tuned Bass EQ (0-18 dB Bass Boost)
Hi-Speed digital circuitry
Full selectable crossover (HI,Full,Low
1-Ohm Stable
Full selectable crossover (HI,Full,Low)
Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation
Platinum-plated RCA level inputs
Platinum-plated screw terminals
Variable low-pass filter (40-200 Hz, 24 dB/octave)
Variable subsonic filter (20-50 Hz)
Variable subwoofer EQ @ 45 Hz
Frequency response: 20-200 Hz
Signal to Noise Ratio: 100 dB
Dimensions: 13-3/4"L x 8-1/4"W x 2-1/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Authorized Internet Dealer
1-year Manufacturer's warranty
if anyone is wondering, i have tested a couple of these and got a good, clean 1600w or so @ 1ohm. The 5500 verions put out a decent 2200 clean @ 1ohm. This was rms of course at 14.2-14.6 volts.
Hmm, you know, 1.6kW or so for 180 bucks really isn't a bad deal at all.
Hmm, lemme ponder this, perhaps I'll use it in my ladies' new vehicle. As part of her xmas present //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hmm, you know, 1.6kW or so for 180 bucks really isn't a bad deal at all.Hmm, lemme ponder this, perhaps I'll use it in my ladies' new vehicle. As part of her xmas present //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just let me know. I'm in the hospital now, my wife just went into labor, but I can still get it out this week.
have fun with the little one bump. if i didnt just get a temp amp this is very nice.
guys ive personally saw 1.5k out of one of these at 13v. not bad amps but like AP or any other cheap brand they eat the power.
Aren't you having a new baby today??GEt off the internet.
LOL - congrats as well.
Yep lol, I'm on my phone right next to her. She just got her pain medicine and if she doesn't go in the next two hours they will do a c section.
probably got the gain turned waaay up. Also remember this is just a 2 ohm stable amp. Make sure your subs are wired for a 2 ohm load on the amp...
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
161
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
550
dross93ranger
dross93ranger
Maysville, KY
corrykid
    May 16, 2024
    May 16, 2024
