Power Acoustic BAMF 4000/1D
This amp is in great shape, it is less than a year old and works like a brand new amp. The bass knob is also included, but not pictured. 9/10 Cosmetic (some minor scuffs on the heat sync) and 10/10 mechanical. The bass knob has a blue LED.
$180 OBO Will also do partial trades (An EQ, 4/2 Channel Amp, Offer anything and how much cash you would give) + cash, but I must get ATLEAST $100 with any trade.
4000W Max Monoblock Class D Amplifier Car Amplifier
RMS Power Rating:
4 ohms: 1200 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2200 watts x 1 chan.
Max power output: 4000 watts x 1 chan.
Fully regulated PWM power supply
Wired remote bass level control included
System distress indicator
Four way protection circuit
Adjustable Tuned Bass EQ (0-18 dB Bass Boost)
Hi-Speed digital circuitry
Full selectable crossover (HI,Full,Low
1-Ohm Stable
Full selectable crossover (HI,Full,Low)
Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation
Platinum-plated RCA level inputs
Platinum-plated screw terminals
Variable low-pass filter (40-200 Hz, 24 dB/octave)
Variable subsonic filter (20-50 Hz)
Variable subwoofer EQ @ 45 Hz
Frequency response: 20-200 Hz
Signal to Noise Ratio: 100 dB
Dimensions: 13-3/4"L x 8-1/4"W x 2-1/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Authorized Internet Dealer
1-year Manufacturer's warranty
RMS Power Rating:
1-Ohm Stable
