FS: NIB Rockford t1000-4adCP constant power edition
jeepintn
I recently purchased this t1000-4bdCP amp from a well known member over on the smd forums. It took about 4 weeks because of a series of delays to get the amp, and in that time my plans have been forced to make a drastic change, so i can no longer keep this amp. It is brand new, still in the shrink wrapping. for those unfamiliar, the constant power model means it makes the same power across 4, 2, and 1 ohm. The birth-sheet says its RMS is quite a bit above the 250x4 claim, i will attach a photo for verification.
10/10 physically, its brand new
10/10 mechanically, its brand new
500 shipped
will be shipped fedex ground
[/url]
way too much power, good for having headroom and keeping distortion low though. good luck with sale
its a beast of an amp, thats for sure. could be bridged to 2 channel mode also, or could be used to run 4 subs in the 350rms range. could also run your front stage off the front 2 channels and bridge the rear channel for sub(s), a lot of options with an amp this stout
up, just saw a sundown 200.4 sold for over 100 more than im asking and that amp puts out less watts at all ohms than this
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
807
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
jeepintn
jeepintn
Greenbrier, TN
jeepintn
    May 24, 2024
    May 23, 2024
