Sold FS: J31Rob's system - Sundown, Fi, DD, Fusion, Pioneer + more.
J31Rob
CarTune Netwerk
We'll start with power:
Sundown SAZ-1500D
Functionality: 10/10 -- Cosmetic: 8/10
$275 + ship / $310 shipped to lower 48
1500 x 1 @ 1 ohm
750 x 1 @ 2 ohm
Special Notes: I replaced power, remote, ground & speaker bolts to nicer hex key bolts. Looks nicer & 100% less chance of stripping bolts out.
SAZ-1500D
The SAZ-1500D is Sundown Audio's entry into the high powered Class-D amplifier market. This amplifier was designed from the ground up to exceed all consumer expectations. From the huge 1/0 gauge power input terminals to the heavy duty heat-sink, this amplifier is built for power. The SAZ-1500D isn't just built for power though, it was designed for the discerning listener who needs hefty amounts of power for subwoofer duty -- it is just as much at home in an install meant for listening pleasure as it is in an all out SPL machine.
SPECIFICATIONS:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* Wired Remote Controller
* MSRP $799 USD
Here you can see the bolts I replaced:
Sundown SAX-125.2
Functionality: 10/10 -- Cosmetic: 9/10
$180 + ship / $210 shipped to lower 48
125 x 2 @ 4 Ohm
200 x 2 @ 2 Ohm
400 x 1 @ 4 Ohms Bridged
Fusion PPAM2000.1
1200 x 1 @ 1 ohm
600 x 1 @ 2 ohm
$175 + ship / $195 shipped to lower 48
J31Rob
CarTune Netwerk
J31Rob
Indiana
J31Rob
