Sold FS: J31Rob's system - Sundown, Fi, DD, Fusion, Pioneer + more.
J31Rob
CarTune Netwerk
We'll start with power:
Sundown SAZ-1500D
Functionality: 10/10 -- Cosmetic: 8/10
$275 + ship / $310 shipped to lower 48
1500 x 1 @ 1 ohm
750 x 1 @ 2 ohm
Special Notes: I replaced power, remote, ground & speaker bolts to nicer hex key bolts. Looks nicer & 100% less chance of stripping bolts out.
SAZ-1500D
The SAZ-1500D is Sundown Audio's entry into the high powered Class-D amplifier market. This amplifier was designed from the ground up to exceed all consumer expectations. From the huge 1/0 gauge power input terminals to the heavy duty heat-sink, this amplifier is built for power. The SAZ-1500D isn't just built for power though, it was designed for the discerning listener who needs hefty amounts of power for subwoofer duty -- it is just as much at home in an install meant for listening pleasure as it is in an all out SPL machine.
SPECIFICATIONS:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* Wired Remote Controller
* MSRP $799 USD
Here you can see the bolts I replaced:
Sundown SAX-125.2
Functionality: 10/10 -- Cosmetic: 9/10
$180 + ship / $210 shipped to lower 48
125 x 2 @ 4 Ohm
200 x 2 @ 2 Ohm
400 x 1 @ 4 Ohms Bridged
Fusion PPAM2000.1
1200 x 1 @ 1 ohm
600 x 1 @ 2 ohm
$175 + ship / $195 shipped to lower 48
Fully Loaded Fi BL 15" 2008 Model w/new motor
Functionality: 10/10 -- Cosmetic: 10/10
Rated @ 1000 rms (will take 2000+ daily)
$190 + ship / $220 shipped to lower 48
BL15
| DUAL 2
Fs: | 33.6 Hz
Re: | 1.4 Ohms/coil
Qms: | 5.21
Qes: .| .28
Qts: .| .27
Mms: | 261g
Cms: | 0.86mm/N
Sd: | 810cm^2
Vas: l | 78.9 l
Spl: | 91.8dB 1W/1m
Bl: | 22.7 N/A
Xmax: | 18mm
Rms: | 1000W *
Sealed box: | N/A cuft
Ported box: | 3-5cuft
Sub OD: | 15.625”
Cut ID: | 14.125”
Mounting depth: | 8.250” *
Displacement: | 0.21cuft
2 Digital Designs 1000 series 8"
Functionality: 10/10 - Cosmetic: 10/10
Functionality: 10/10 - Cosmetic: 7/10
$80 + ship / $110 shipped to lower 48 for mint condition sub.
$60 + ship / $90 shipped to lower 48 for sub with hole in surround.
Rated @ ~500-600 rms, will take 1000+ daily.
Don't have specs on them, can be found if you look.
CSS SDX Motor & Basket Assembly -- XBL^2 motor, would make for an AMAZING daily sub, TeamPSI quoted me a wonderful price for 2000+ rms softparts to go with the motor.
$60 + shipping / $90 shipped to lower 48
Last but not least, I've got two 6" pipes, one a little over 35", one is ~37"..
$15 + ship / $30 shipped to lower 48 for ONE pipe
$25 + ship / $50 shipped to lower 48 for BOTH pipes
Price on the Fusion?
Price added, PM me with an offer, I'll entertain all offers.
I WILL consider trades on the following items:
Item / will trade for
Fi BL 15" / DD 9515 - SSA Icon 15" - Sundown Nightshade 15" - AudioQue HD3 15" - or 2 12" woofers of some sort
Sundown SAZ1500 / IA20.1 - Amp of 1800+ rms @ 1 ohm
Sundown SAX125.2 / 2 or 4 channel of same or greater power
Fusion 2000 / Battery - Alternator - Component set - Tweeters - 1/0 wire
(2) DD 1008 / Selenium Horn Tweeters - Component sets with or without tweeters
Pioneer DEH7800 / Pioneer 880 - Pioneer 800 - Pioneer 9800
J31Rob
CarTune Netwerk
J31Rob
Indiana
J31Rob
