DD 3512 D2 with a B series motor.Has dual 2 ohm coils and will take 1500rms daily. Cone is a little off colored but works flawlessly.
$125 shipped
The American Bass is the XD 1800. Does 1800 x 1 @ 1 ohm and will run at 1/2 ohm. Has sratches and rub marks on the top still works great though.
$220 shipped
Ma Audio HK3X 3-way cross over BNIB(took out for pics).
# 3 RCA Inputs (Front, Rear, Sub)
# 3 RCA Outputs (Front, Rear, Sub)
# Subwoofer Input Selector (Mixed/Direct)
# 18dB Crossover Slope
# 40 Hz - 4.2 kHz Variable Subwoofer Control
# 0 - 180 degree Subwoofer Phase Control
# 65 Hz - 4.5 kHz Variable Rear HP Filter
# 65 Hz - 4.5 kHz Variable Front HP Filter
# 300 Hz - 4.6 kHz Variable Rear LP Filter
# HP/Band Pass Selector Switch for Rear
$75 shipped
HUGE front mount intercooler. Its a Godspeed type F.
max horsepower capacity : 600-650HP
core length 17.5"
core height 11"
core thickness 3"
inlet/outlet 2.5"
Working pressure 35-40 psi
Overall height 15"
Overall length 20"
pressure drop 0.2-0.5@15psi,2-5psi@35psi
material 100% aluminum
design bar and plate=high flow
construction machine cut & stamped, hand welded
finish polished
$135 shipped
And the pics....
American Bass XD1800
MA Audio HK3X
Godspeed TypeF
DD pics in a few
$125 shipped
$220 shipped
$75 shipped
core length 17.5"
core height 11"
core thickness 3"
inlet/outlet 2.5"
Overall height 15"
Overall length 20"
finish polished
$135 shipped
And the pics....
MA Audio HK3X
Godspeed TypeF
DD pics in a few
