Fs/ft audiocontrol 6xs
  • 1
Austinw88
Used 6xs in working order. Looking to get 100 obo or trade for a decent set of 6.5 comps.
Product Highlights:
6-channel Linkwitz-Riley electronic crossovergray steel chassis with gold-plated RCA jacksline driver with adjustable output (up to 9 volts)top-mounted controls for easy adjustment6-channel inputs (front, rear, sub)8-channel outputs: front high-pass (250 Hz and up), front low-pass 90-250 Hz), rear high-pass (250 Hz and up), subwoofer (30-90 Hz)balanced inputs eliminate noisePFM subsonic filter (18-100 Hz at 18 dB/octave)frequency response: 10 to 100,000 Hzsignal-to-noise ratio: 110 dBmaximum output level: 9.5 volts (13v peak)fuse rating: 2 ampssize: 7-1/4"W x 1-1/4"H x 7-3/4"Dweight: 2.5 pounds
Sent from my XT1030 using Tapatalk
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
720
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
Austinw88
Austinw88
South Carolina
Austinw88
    May 24, 2024
    May 23, 2024
