Front stage questions
Here it goes. My main objective is to upgrade the stock 6.5mids to ID OEM mids and push them with a 125watts.
I know nothing about front stage what so ever so with that said....
First of all I'm running everything off the stock oem stereo I have a hi-lo converter connected to my 6x9's for subs. I also have stock tweeters which i don't need to replace at the moment.
* In order to hook up the ID OEMs would i need to purchase anything else besides the amp? like crossovers or is that not necessary since i'm not buying a whole tweeter/mid/xover set
OK SO..................................
Mids = ID OEM (single 4ohm)
Lets say i bought this amp here:
http://www.icebuyer.co.uk/reference-7521a-2-channel-amplifier-p-11464.html
* 2-channel Amplifier
* 142 watts RMS x 2 channel at 2 ohms
I would need to wire parallel right? like this:
http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~2~I~41
*2ohm load for 142watts
1) basically i need to know how to wire all this... what goes where?
2) how would i wire the subs in parallel if they're on opposite sides of the car?
3) should i be looking at a completely different amp or is this one fine?
Kastlez_
Kastlez_
Bay Area, CA
Cpyder
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
