Rasheedhos
Banned
is the frequency response on a subs start at 40 hz what would be a result if i tune the box to 35 hz?
It must be like a 4" sub. But if thats the case there wouldnt be much "SUB" to it.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifis the frequency response on a subs start at 40 hz what would be a result if i tune the box to 35 hz?
.....right.......It must be like a 4" sub. But if thats the case there wouldnt be much "SUB" to it.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
So it would be more of a midbass driver then a actual subwoofer, yes.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.giffrequency response means output drops 10dB, not that it can't play below it
it's most likely the frequency response of a driver that was designed to have a high frequency peak
I'd sure like to know where you draw the line between woofer and subwoofer???? Because there are subs out there that don't really sound like subs to me.
I mean I understand how it's supposed to work. I just don't think there is an industry standard and it can be misleading, imo.Well take for example a Kicker SSMB6 midbass driver, the freq response starts at 30hz, whereas a reg sub usally is lower like 20hz.
If a driver is not designed to play notes below 40hz, I wouldnt call it a subwoofer. I mean if you wanted to listen to music below 40hz, what would you add to that system, a subsonicwoofer/infrasonicwoofer?I mean I understand how it's supposed to work. I just don't think there is an industry standard and it can be misleading, imo.
I agree.If a driver is not designed to play notes below 40hz, I wouldnt call it a subwoofer.
