Freelanders Build Log
Did a little bit more to the internal port brace so it didn't take up as much volume, came out pretty nice even though you aren't going to see it...
Picked up the "High Sexage" 1/0 from Jmanpc tonight (30+ft) Thanks again Jordan //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Also won a set of Helix HXS 136 MKII 6.5" Component Set a minute ago. Heard good things about them. I lost the auction for the Helix PRECISION LINE HXS 236 / G Component set at the last second //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I'm thinking of going with the Hertz HSK 165 Component set up front, anyone have any other suggestions? Does anyone have any experience with the Helix Comps?
anyone have any experience with the Helix Comp sets? I'm also wanting to hear if the Hertz HSK165's would work good for my front stage.
My amp is rated at 75wrmsx4 @ 4ohm 12v. So I'm figuring at 14.4v it will do somewhere around 125wrms. Its a beast of an amp built in 1991.
Got 30+ft of 1/0, ordered from knukonceptz a 200amp circuit breaker for up front, Digital Fused distribution block for the rear, two battery terminals that accept three 1/0 inputs each. My Helix Comps will be here Monday. I hope to order the Hertz HSK165 later this week or next week.
I also sold my HU so I can get an Alpine 9887 so I can run active on the Hertz HSK165's! Will start installing everything very soon!
The box is almost ready for prep/paint. I need to cut the sub hole out then cut out the second baffle to flush the sub. Then it will be sanded, filled, sanded, primed, sanded, then finally painted hammer black //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I hope it sounds pretty good, my first box using aero's.
true, but the Helix speakers you have make up for it.
Yea I can't wait to test them out, they get here Monday!
I've made up my mind to get the Hertz HSK 165's also //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Gonna be some good sounds comin out of this car. Can't wait to see some install pics. Curious how hard the Land Rovers are to work with too.
Freelander
Freelander
Jacksonville. FL
Hitler
vegang
vegang
