Freelanders Build Log
Freelander
Finally starting to build the system I want. I got a 15" FiQ (Thanks Jmanpc) a MMATS D300HC. Probably going to build the box sometime this week. 4.04ft^3 with two 4" precision flare ports 17" long. Looking for another battery to put in the back to try to keep up with the d300hc. I also have a Clarion 3200A 4-channel that I bought brand new (made in 1991) that is rated 75wrms 4ohm at 12v. I haven't decided what components I'll be putting up front. I might stick with the stock components in the rear. This will be in a 2003 Land Rover Freelander.
yea thats only 4awg monster cable. Its thicker than it looks in the pictures. I just bought a Kinetik HC800. I'm going to buy some "High Sexage" 1/0 wire from Jmanpc for the batteries and big three and then run the 4awg from the HC800 to the amp since its going to be such a short distance.
Nice gear, should be a nice build. What's the box going to be tuned to? Also, what are the specs on that amp?
The box is going to be tuned to about 32hz. The amp is RATED 600wrms @ 4ohm, 1200wrms @ 2ohm, 1900wrms @ 1ohm. The amp benched I believe 2148wrms @ 2ohms 14.4V.
After I get off work tonight I might go pick up the MDF so I can start building the box tomorrow morning. Neighbors don't like me running power tools at 9PM for some reason especially when they know its to make my audio louder //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Freelander
Freelander
Jacksonville. FL
Hitler
vegang
vegang
