Free Box designs.
Here you go!
I currently have (4) 12" D2 Eclipse SW7200s in my 99 Nissan Sentra GXE. They are facing inside the cab. I hit 145.9 on an AC180. So it's loud, but I don't like sealed.... I'm into ported.
I need a box built for 3 12s ported, or a really BIG box for 2 12s ported.
I measured my trunk and the specs are as follows:
Opening of the trunk: 36" (That's sliding the box straight in - if angling the box up you only have 12" to work with)
High: 16" MAX
Length: 43" (43.5") MAX
Deep: 22"
This is the current box I have in the trunk:
Front of the box: 26" Long
Back of the box: 43" Long
Angle from front to the side: 13"
Square side: 13"
... (Which makes it 26" Deep)
Hieght: 14
These are some pictures of what I'm talkin' about:
These (2) are pictures of the angle part of box
http://i214.photobucket.com/albums/c...121507_010.jpg
http://i214.photobucket.com/albums/c...121507_011.jpg
These (2) are pictures of the trunk opening:
http://i214.photobucket.com/albums/c...121507_012.jpg
http://i214.photobucket.com/albums/c...121507_007.jpg
I'm really hoping that I can get a (3) 12" ported box with these dimensions... But if not, I guess I'll have to go w/ 2 or stick with what I have.
Thanks in advance, and let me know what all can be done.
i need an enclosure 12 cubic ft internally after sub port and bracing.its for 2 18 treo ssx subs.
sub displacement is 0.31 ft or 8.90 L per sub.i want a 200 sq inch port tuned to 35 hz.box width is 48 hieght is 25 deepth is 28.thanks
hey jesse if you could do this for me i would appreciate it man.i got a 93 chevy 1500 reg cab pickup. i am putting 2 12"s in there(or atleast hoping to) they are the memphis m class. 5.5 in mounting depth. i would like to have a box that would enable my seat(drivers side) to not have to be moved up at all but if the other seat(passengers bench seat) needs to be then thats fine but if there is a possible way to have a box all the way across with out having to move the seats up that would be good. but if there isnt ill move the bench seat up and just have the box behind there instead of behind mine. sealed is fine but if there is a way to make it ported and tuned to like 35 hz then let me know.
thanks,
-eric
Hey man here's my spec's of the hatch.
width i can go: 3ft 3/8
Length 29 1/4
height of box i can go 2ft 1/4
Sub's goin in Two 15 inch audiopipe txx-ap15
Here's specs of subs
xmax(inches): 0.45
vented box recomended cu/ft : 4.67
Want to do ported tuned at 35hz Subs up port back . port on passenger side
Let me know man thanks in advance:D.
http://subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=15&Dia=9&Xmax=11.4&Vd=.1&NumW=2&Vb=4.7&Fb=35&Qts=&Vas=&Fs=&CE=0
The colors of the box should match the colors in the link. Just remember you wanted the port on the other side
Here you go!
High: 16" MAX
Deep: 22"
Square side: 13"
Hieght: 14
your links don't work, sorry
i need an enclosure 12 cubic ft internally after sub port and bracing.its for 2 18 treo ssx subs.sub displacement is 0.31 ft or 8.90 L per sub.i want a 200 sq inch port tuned to 35 hz.box width is 48 hieght is 25 deepth is 28.thanks
you want subs up port back? more or what kind of car it's going into. are you dead set on 12cubes @ 35hz or could it be more like 10-11 cubes?
2 12" pioneer 5000spl going in the bed of silverado truck,external mesurments are w 46 x h 17.5 x d 19 tuned@35 ( inverted setup, seperate chambers)
sub would be mounted in the 46 x 17.5 section of the box,using 1" mdf
p.s.
depth could be changed if you think of a better size box (between 19-22" )
thank you for your help
looking to build sealed, downfiring enclosure to replace center console in chevy crew cab.
Dimensions are L=34" W=13.25" H=14"
2-10"w6'S
10W6v2 DRIVER SPECIFICATIONS
10W6v2-D4
Free Air Resonance (Fs): 28.5 Hz
Electrical “Q” (Qes): 0.497
Mechanical “Q” (Qms): 8.458
Total Speaker “Q” (Qts): 0.469
Equivalent Compliance (Vas): 1.18 cu. ft. / 33.4 liters
Driver Displacement: 0.068 cu. ft. / 1.9 liters
rcnshoe
VW Pimp
rcnshoe
Next to you.
roarzorz
