Free Box designs.
2 12" pioneer 5000spl going in the bed of silverado truck,external mesurments are w 46 x h 17.5 x d 19 tuned@35 ( inverted setup, seperate chambers)sub would be mounted in the 46 x 17.5 section of the box,using 1" mdf
p.s.
depth could be changed if you think of a better size box (between 19-22" )
thank you for your help
I used RE's calculator. the subwoofertools.com won't let you change the board thickness. hope you like it.
3 cubes per chamber @ 35hz
individual chambers:
Bottom Plate: 23 x 22
Top Plate: 23 x 22
Left Plate: 21 x 15.5
Right Plate: 20 x 15.5
Back Plate: 23 x 15.5
Front Plate: 19 x 15.5
Port L1: 17 x 15.5
Port L2: 5 x 15.5
single 12" memphis m3.. 31w x 14h x 13d at 32hz.. and 2 12" massive cw 48w x 18hx 18d tuned around 38-40
ive been tryin to make plans for these boxes on winisd and re.. but a lot of people say re is no go and winisd.. i get too confused.
thanks
i have a 95 honda civic 2dr coupe and running 2 12" Mach 5 SPL 12's powered by 2 MTX ELITE4000
need a box designed for spl /street /drive by spl
after the box is built and put in my trunk will be walled off only seeing the port and subs. so prefer subs facing inside the car
15"H
38"W
28"D
thanks
Bsihop
Can someone help me with a design for a single Kicker L7 12", I was thinking of 3-3.25 cubes at 34hz? Its going inside a 4runner and I have lots of trunk space so dimensions can be anything.
thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how about a ported box for a 15" Fi Q...going into an '01 ford taurus sedan...would like ported, anywhere from 30-35 hz (you can use your expertise:)) would like it to be no more that 30w x 21d x 17 h...thanks!
i got a max of 20"d x 18"h x 48"w to play with in a 98 ford windstar would like a slot port tuned in the 32 to 38 hz range it is for 2 12" strokers parameters are fs 32.6 hz Qts 0.72 Qms 9.94 Qes 0.776 Vas1.31 cu ft any help would be very great
rcnshoe
VW Pimp
rcnshoe
Next to you.
roarzorz
