Free Box designs.
49x 40x 20 16 10s tuned to 35
Had to add 2 inch in H to fit speakers
i believe it's google's sketchup. i've been trying to use it for a while and i don't know how to add thickness to the boxes i make on it. nor do shadowing or anything. hey rcnshoe would you mind giving me some help on how you come out with your boxes on sketchup?
I learn pretty quick with all computer related things. Figured how to use the program by reading there forum and messing around with the program. I use http://www.carstereo.com/ To help figure out the ports.
2001 Nissan Maxima
12" Fi Q w/ BP Power Option D2
Max External Dimensions
D X W X H
16" X 30" X 15"
Double Baffled
Tuned to 32Hz with single slot port
I would suggest around 2.25-2.5 cubes net with 28 square inches of port, but it looks to me like you need no suggestions. So please if you think you have a better idea, go with it.
Thanks in advance, anything is greatly appreciated
2 pioneer 12" 5000spl , w 46 x h 17.5 x d ( up to 22 ) , sub would be mounted
in the 17.5" section, tuned@35 seperate chamber for each sub if its possible
thanks alot
ps
using 1" mdf all around
Hey man i just got home from work now 3am here so can't go out and take specs of hatch now but i will for sure 2morro shoot you a pm with specs and what sub's im using:D. Thanks in advance man.
How about...
Dayton RSS265HF-4 10" Sub
Sub must be in Down firing config, flush mounted....using a slot port that goes out the top (out one of the sides, doesn't matter)...
the actual box must be a 12" x 12" (picture a standing rectangle)... but the height can be as high as needed to fulfill the requirements of the box...
Tuned to 20hz....
edit; 3/4" MDF...will be used..
rcnshoe
VW Pimp
rcnshoe
Next to you.
roarzorz
NorthFramingham
    Jun 30, 2026
