I thought about that after I did it. I did scuff up the edges a with sand paper before I glued it on. Another reason why I'm gonna glass the outside.In the future do not just resin the top before hand. The wood glue did not bond properly im sure
I'd get coax versions of whatever you're running up front.Also what should i put in the rear of the car?? Another set of components, just Mids, or coax??
I was wtf'ing when I saw that.In the future do not just resin the top before hand. The wood glue did not bond properly im sure
Will cover imperfections on the outside of the box that will shine when painted. Will also like you said seal the box.why glass the outside? glass the inside seam... IF you have air leaks or it rattles
