Ford ranger floor hump wtf!?
  • 7
build a false floor. really simple to do.
---------- Post added at 05:26 PM ---------- Previous post was at 05:25 PM ----------
or you could just wall it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
With the false floor, do you just screw it straight into the truck floor?
no... you just build it and set it in. very very simple to do.
509
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
ChucklezZ
ChucklezZ
Patton, PA
04murdalanche
Brendon Jenness
    May 8, 2024
    May 8, 2024
