focal highs!!!!!!!!!!!!
MB Quart QSD 216 i can get these for 300
Speaker Size 6-1/2"
Design 2-Way Component
Tweeter Design N/A
Tweeter Composition N/A
Woofer Composition N/A
Woofer Surround N/A
Sensitivity 90 dB
Frequency Response 35 - 32.000 Hz
RMS Power Handling 80 - 150 watts
Peak Power Handling N/A
Impedance 4 ohms
Top Mount Depth 2.5"
Bottom-mount depth N/A
Cutout Dimensions 6.61"
Q-Series QSD 6-1/2" Component System
Midrange with 37mm (1.5") voice coil is used - Former made of Kapton foil (a temperature resistant plastic) that can withstand extreme heat
25 mm (1") Titanium Dome tweeters with a highly elastic butyl rubber surround
Balanced Temperature Technology is used throughout
Tweeter level can be adjusted in 2dB steps up to -6dB
Built-in light bulb on the crossover networks to extend the life of the tweeter using overload protection
Ability to upgrade the midbass with the Add-A-Woofer-System
MB Quart easy speaker connections. Connection types include solder, screw-down, spade or bare wire
Designed specifically for low-profile installations. The diecast aluminum baskets can be installed in most factory locations with little or no modification. They are lightweight and extremely rigid
A new variation of the WPC process used in QSD is applied in the QSC component system.
Speaker Size 6-1/2"
Tweeter Design N/A
Woofer Surround N/A
Sensitivity 90 dB
Impedance 4 ohms
If $300 is for brand new, especially authorized, that's a good deal for those.
get the focals. i had them and loved them. If you wanna spend twice as much, the polykevlars haev a lil better tweeter, quite a bit more midbass, and a little brighter. BUT DEFF. get a good clear amp for them (Audison, sundown, zapco...)
I'm not a big fan of MBQuart tweeters either...
takes getting used to, but the upper series are much different then the low end stuff...for 300$ Qline is a really good buy...
edit: at least for my standards as i dont really know what u can get in the states for 300$...your prices and mine are....somewhat different:crap://content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif:crap://content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
searcy1321
searcy1321
n/a
Echo42987
Mike Mccabe
