First system
Can't win em all man. I've heard my buddies similar build to this and I think it'll do what I'm looking for.
Man, It all comes down to what you want and what sounds good to you. Personally, I think the T500BDcp is a excellent choice, just a little overpriced for what you get...The AP i mentioned is total junk that does close to rated power. I was just making a point. And yes for a few hundred less, better can be had.
I feel like I just wasted 5 mins of my life I can never get back... Here I thought we were helping him get a pretty sweet system for a grand and that all went out the door. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Well I'm glad you guys are trying to help me but it doesn't really help when I already have all this equipment. I just want to know more about them and others opinions.
Well it's mediocre equipment at way too expensive prices. And if you paid a grand for all of it and getting installed, you got ripped off.
Next time you ask an opinion, don't buy the crappy equipment before you do so.
The best thing you could do at this point is return it all. For $1,000 you could have one very nice system.
@keep_hope_alive you would run this sub before the P2s? Interesting....
[quote name='keep_hope_alive']
Daily Deal - Sonic Electronix
[/QUOTE]
(click the link)
Hmm..well, the subs are mediocre at best for what they are. Not too sure about the tuning of the factory junk box (5/8" MDF). Probably tuned to 40hz or so to maximize the punch 45hz bass boos circuitry in their amps. They will make a little noise though. Too bad you bought the D4 subs because the 500 Bdcp is a good 2ohm amp that will work at 1ohm, but does not put out any more wattage at 1ohm and actually loses 11% of it's efficiency at that impedance. Bad choice of subs/amp combo. The KW is meh, ok for 140 bucks.
I get it all setup on saturday and will defiantly let you guys know what I think of it. Any advice on tuning, flexing or any other stuff? I'm pretty new to this stuff.
the installer should take care of all tuning. you shouldn't have to change/adjust anything on the amp. but take non-blurry pics of the amp settings after you get the car back and we can evaluate/review.
you should take care with the volume control. in the end, your use of the volume control will determine if you damage your gear. note that you can only be so loud with a given system/investment.
post pics of the end results (we like pics showing wiring routing/connections). ask the installer to take pics during install (this will keep him honest).
the Kenwood has built-in high pass filters for the speakers - make sure these are turned on (will be set around 80Hz-100Hz) depending on the sub amp low pass filter. you do have some tuning ability in the HU, but as a general rule - an eq should be used to cut frequency peaks, not boost. boosting increases change for clipping (by causing clipping at a lower HU volume).
your stock speakers should sound much better on the Kenwood HU (compared to stock HU) but won't sound great. if you hear distortion in the speakers, that's inherent with any head unit amplifier above 1/2 volume or so. you shouldn't need to boost any bass EQ settings since you have subs now.
when you get it installed, read the manual for the HU control/features/setting. if you have any specific questions on HU settings, ask.
I wouldn't worry about flexing with what you got.
I'll make sure to take a loud of pictures for you guys. Ya I figured on going easy on the volume to try to find a good volume that won't damage anything. Don't I need to adjust the amp after a while? Thanks alot
Head unit should clip after 25 so don't go above that.
This is about correct. I have a Kenwood 448U, and depending on your EQ, anywhere from 23 to about 28 or 29 will start to give you clipping. At that volume, your full range should be easily overpowered by your subwoofer.
I do need to upgrade to one of the Excelon units though...
DatAudio
DatAudio
Michigan
DatAudio
