First flare port attempt.
tyler_fitz
They call me Weezer
I think it should sound and look real good. What do you think?
to be honest man, you could have achieved that same effect with a bunch of boards cut on an angle, and it would have been less cuts.
You should cut them alot closer together over the entire diameter of the cut , should yeild better results.
hope that helps, if not there is a tuturial on ROE
Very Nice!! I have used regular sch.40 PVC in the Past for some box building while learning to do my own box tuning. Works great. Istill have a...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
695
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
868
840
tyler_fitz
They call me Weezer
tyler_fitz
Hutchinson, KS
Propimp
    May 16, 2024
    May 16, 2024
