- Thread Starter
- #31
I understand. So the port itself i need to add sideways correct i forget the termif you do the front and back 12.75*34.5 you can make that the back peace and cut the front 31' that way you don't have to worry about cutting out a whole.so cut sheet would look like this.back 34.5*12.75
front 31*12.75
top/bottom 36*24
sides 12.75*24
port 12.75*12
if you lay the bottom down, the sides will flush with the bottom on all sides. same for the top then the back and front will sandwich in-between the t/b and sides
another option is to cut the front in 2 pieces each 15.5" and put the port in the middle. this is the best way.. you need two pieces for the port same size 12.75*12. they go inside the box behind the front and sandwich between the top and bottom..
you understand what I saying?
Sent from my Trio AXS 4G using Tapatalk
