First box 2 sq hds12's
Sad the only sander i have is a belt sander and i was thinking about it. But how do i know what straight actually is. Think my guide board choice may not have been lol
Sent from my Trio AXS 4G using Tapatalk
It will be okay if it is not perfectly straight. If you are worried about sturdiness, add some bracing. If there are any gaps, just seal them up with chaulk on the inside of the box. As long as it is sealed up well, it should work out alright //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I didn't trust myself or my tools to make perfectly straight cuts so I had the place I bought the wood cut it for me. All that was left was assembly and cutting the circles which is easier.
Ya i had them make the first cut so i could fit in my car but i heard they dont care about accuracy and based on how fast the kid cut it probably is true. If im gonna have somethin screwed up ill screw it up myself
Yeah I guess it depends on where you buy the wood and who is working that day.
Screwing up and breaking things is the best way to learn. Frustrating as hell though. I bet you won't screw up the cuts on your next box. Hopefully this one works out for you man. Good luck!
Follow this design just like it says. Attach the port in the center between the subs. You basically just make a square box, cut 3 holes, two for subs one for port and glue on the port to the box. Try with low tuning first and start chopping the port shorter inch by inch until you get the sound you want. Use threaded rods or wooden dowels to brace the box. when it says number of extra baffles 1, it means have an extra front side cut and glue them together so it can support the subs properly. Use Birch ply or 7 layer or higher plywood. MDF will be heavy.
Buy this Take a tape measure and try to get as close as you can to 8 inches in inner diameter because they all vary in size.
Shop QUIKRETE 48-in Concrete Tube Form (Common: 8-in; Actual: 7.5-in) at Lowes.com
What is the best way to glue the port to the box?
Well i finally got my circ saw and other stuff needed to try making my box.. Even followed guides online and well its alot harder than i expected. Today was cut day and it didnt go so pretty. Im still gonna finish making it. But she aint gonna be pretty. What i thought were straight cuts were off.. Not sure how its gonna affect sound but at this point i started this ***** and im finishing. I can only try and brainstorm how im gonna get my sub cutouts and port to go.. Pics over the weekend. If im not to ashamed
you need to get you a straight edge brother. you measure from the blade to the edge of the saws guide and add or subtract if from your original measurement. for example from the front of the blade to the edge of the saws guide is 2" and your cut has to be 14". mark your 14 and mark your 16".. then get your guild and put your guide on the 16" mark clap it down and line your saw up.. you should line up directly with the line. sometimes you gotta use the saw 180 degrees to make some cuts. just remember to subtract and place you guide on the other side. it takes a few times to get it.. don't get frustrated it takes a while to master it..
Whats the best way to cut the sub holes? I bought a jigsaw but trying to measure 11.25/2 on a tape measure i got a bad feeling its not gotta turn out well
a router works best but get a fine tooth wood blade and take our time with the jig if you don't have a router..
Take a scrap piece of wood and drive a nail through one side of the piece then measure from the nail 5 5/8" and drive a nail into that spot. That first nail you can then hammer into the baffle. The other nail will dig a mark into the wood when you turn the wood in a circular motion. That will be 11.25" for the cutout. Then take a pencil if needed to make the mark darker. Drill a hole anywhere near that mark and use your jigsaw to cutout the sub opening.
jasper jig.
Cutting mounting holes with the jigsaw is so 90's...lol
Actually, Stangs idea is good. Except I would find the center of your mounting hole circle and then drive/screw a drywall screw in the wood partial way. then find some string and tie one end to the nail/screw and the other end to a pencil. Measure out whatever the mounting lip of the sub is, then take that apply it to the circle and take that pencil attach it to the string and you'll have a nice circle or close to one. Make sure you mark which one to cut tho.....word of advice, measure twice cut once.
I was gonna go with jeff's circular port idea. But i would rather do slot but sounds more difficult to get tuning correct.
while there in nothing wrong with jeffs' idea. I recommend this because the port helps strengthen the box. its not much harder to build. you would cut out a hole in the box on the same side as the sub 3.5wide*12.75 high. then cut a peace of wood 12.75x12. mark 3.5 inches from the side of the box down to 12 inches on top and bottom then line the peace up with the hole you cut and screw it from the front top and bottom..
if you do the front and back 12.75*34.5 you can make that the back peace and cut the front 31' that way you don't have to worry about cutting out a whole.
so cut sheet would look like this.back 34.5*12.75
front 31*12.75
top/bottom 36*24
sides 12.75*24
port 12.75*12
if you lay the bottom down, the sides will flush with the bottom on all sides. same for the top then the back and front will sandwich in-between the t/b and sides
another option is to cut the front in 2 pieces each 15.5" and put the port in the middle. this is the best way.. you need two pieces for the port same size 12.75*12. they go inside the box behind the front and sandwich between the top and bottom..
you understand what I saying?
furbee86
furbee86
Aurora, CO (denver area)
furbee86
