Finalizing system ~$600
braindrift
WANT
-Clean sound over loudness
-60-70Wx4 200-250x1 at 4ohm 5 channel amp
-accurate bass
!!!!!!!!!!!!!!!!!!!Not sure about comp set and sub!!!!!!!!!!!!!!!!!!!
Front
http://sonicelectronix.com/item_7755_Focal+165+A1.html
or
http://sonicelectronix.com/item_10190_Memphis+15-MSYNC6.html
or
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17540
Rear
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17545
Amp
http://www.sonicelectronix.com/item_10142_MB+Quart+PAB+5400.html
Sub
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17537
or
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6476
-Is amp good for what I want? (Want to keep amp power low don’t want to but a new alt.)
-Comp set concern how should I match the sens., rear set at 88db.
-Sub unsure probably PG.
-Heard only PG, like.
focal front stage and RSD for rear or forget rears and get the next grade up of focals for the front, or deadener for your front doors instead of rear fill.
Good subwoofer, great amp pretty awesome for under 600.
braindrift
braindrift
eb, nj
skateboardkid
michigan born
    May 14, 2026
michigan born
    May 14, 2026
