final ohm load question
Mmmmm..Subs
Bump, Bump, Bump
how do you figure out your final ohm load? i was gonna wire my sub at 8 ohms and my amp bridged at 4ohms.....ohms are like chinese to me it confuses me any help would be apreciated.....my sub is an insignia 12" 4ohm DVC amp 2ohm stereo stable and 4 ohms bridged
Amp:
SONY XM-752X amp, crossover, bass boost,
2ohm stereo stable, 4ohm bridged, 75x2w or 200x1w,
45hz bass boost, 400w max
Sub:
Insignia 12" 4-ohm dual voice coil 1800 max 600 rms
you need a different amp, i know you dont have the money but your not going to be able to power this sub efficiently. wait till you get a new amp it will be worth it. you cant run your amp bridged with this sub because it is a D4, if it was a D2 then you could run it bridged with a final load of 4 ohms. your amp is not stable under 4 ohms while bridged.
It also lowers the amps efficiency and raises the current draw.
462
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
299
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
994
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
Mmmmm..Subs
Bump, Bump, Bump
Mmmmm..Subs
Finleyville, Pa
Mmmmm..Subs
    May 16, 2024
    May 16, 2024
