final ohm load question
Amp:
SONY XM-752X amp, crossover, bass boost,
2ohm stereo stable, 4ohm bridged, 75x2w or 200x1w,
45hz bass boost, 400w max
Sub:
Insignia 12" 4-ohm dual voice coil 1800 max 600 rms
you need a different amp, i know you dont have the money but your not going to be able to power this sub efficiently. wait till you get a new amp it will be worth it. you cant run your amp bridged with this sub because it is a D4, if it was a D2 then you could run it bridged with a final load of 4 ohms. your amp is not stable under 4 ohms while bridged.
Mmmmm..Subs
Bump, Bump, Bump
Mmmmm..Subs
Finleyville, Pa
Mmmmm..Subs
