Final Decision: I NEED HELP
venom107
The Graveyard Shift
Im going with the Audiobahns some may think this is stupid but hey Ive heard them before and i like em. All you Audiobahn fans I need some help Im going with the Dual 12 Subs and I need to know which Model is the best. Here are my Choices
ABV125Q
ATB12Q
ABP12
ABP122Q
Which puts out the most SPL? There are so many choices but I know this is the way I want to go. Especially since they are already made to Audiobahn Specs. If you need help desifering the Models go to http://www.audiobahn.com Thanks for all the help.
I don't remember seeing those models numbers anywhere, but I have a single AW1505X in a 3.2 cubic foot custom ported box, tuned flat to 32 Hz. I am pushin it with a Planet Audio P1250D in my 94 SC2. It hits pretty hard, and the formula says I should be hittin around 145dB. Anywayz, I would check the Efficiency numbers of all the subs and pick the best one that also meets what you want. Sealed....Ported?
Originally posted by venom107 Im going with the Audiobahns some may think this is stupid but hey Ive heard them before and i like em. All you Audiobahn fans I need some help Im going with the Dual 12 Subs and I need to know which Model is the best. Here are my Choices
ABV125Q
ATB12Q
ABP12
ABP122Q
I've never seen/heard of these models before...
Oh ok I see them now.... the 122Q has very high senstivity, which results in higher SPL. They all have 800 rms so that will be the same... in the decibel formula, the higher the sensitivity, the higher the SPL. Plus, the plexiglass in the bandpass box will pick up the higher bass frequencies better than the regular ported box. So, that would be my pick, however I think it is also the most expensive.
venom107
The Graveyard Shift
venom107
Independence, Kansas
jemorgan85
