Fiberglass box Help
sofbass
Ok, well i made a really stupid mistake, i didn't seperate the two chambers for the subs, its going to be 2 12" L7's ported. I plan on using some PVC pipe for the ports and not vented.
Here's some pictures of the box.
http://i7.photobucket.com/albums/y271/sofbassist/DSCF0460.jpg
and you can see it doesn't have a piece of MDF to seperate the two subs in this one.
http://i7.photobucket.com/albums/y271/sofbassist/DSCF0461.jpg
its on the final stages of bondo, and i was bored so i decided to come up with a few painting ideas, thats why it has spraypaint on it.
but anyways, the way im thinking about fixing this, is going and getting some balsa wood, making a kind of frame out of it, and just laying some glass over it and make a fiberglass wall to separate the two chambers. I plan on running ports out the top.
Is it even necessary to separate the two chambers? Im pretty sure it is, but if it isnt, then it will save me a lot of time.
If worse comes to worse, i might just cut off the fiberglass front, and make new top, bottom and sides for the box, that way i can separate the two chambers.
Any help would be greatly apprecieated!
It is not nessacary to seperate each sub.
But it is a debatable subject.
What amp do you plan on using to power this? That would help is the answer.
If your gonna run a single amp in mono, then don't worry about it.
If your gonna run a single amp in stereo, maybe.
If your gonna run an amp on each sub, then yes, seperate them.
I would be using an SX1250.1
How should the ports be aligned? I was planning on laying a peice of plexi on top of the box, and have a neon behind it to make a kind of illumination effect, and then im going to have a fiberglass amp rack on the top of that. Now i plan on running the two 4'' ports out of the top in a sort of \ / way, the \ / being the ports.
Is there any advantage of keeping them in seperate chambers even if i am using a mono amp? Or is there no point
sofbass
sofbass
Minneapolis, MN
sofbass
michigan born
    May 14, 2026
michigan born
    May 14, 2026
