tungnguyen 10+ year member
60.9CS 6.5"
692.9I 6"x9"
clarion 746
bought all of them new on June 2012, i sold my car so it need new home. used but in good condition, i lost hex key for open a tweeter but you can used your. one label of the speaker and EQS 746 fall off
•Infinity Kappa 60.9cs 6-1/2" Kappa Series 2-way Component Speakers System
•Power Handling: ◦Peak: 540 watts per set / 270 watts each side
◦RMS: 180 watts per set / 90 watts each side
•Sensitivity: 95 dB
•Frequency Response: 45 - 25000 Hz
•Woven glass fiber cone woofer
•Rubber surround
•Edge driven UHF dome tweeter
•Unipivot patented rotating tweeter allows tweeter to be directed at the listener's location
•Direct connect computer-optimized, voice-matched outboard passive crossover for superb detail and accuracy
•Tweeter level adjustment on passive crossover to add or subtract 3 dB output
•2 ohms impedance
•Cutout Dimensions: 5-1/8"
•Top-mount depth: 2-7/16"
•Infinity 6"x 9" Kappa Series 2-way Speaker System
•Power Handling:
Peak: 660 watts per pair / 330 watts each
RMS: 220 watts per pair / 110 watts each
•Designed with Woven glass fiber woofer cone
•Rubber surround
•Features Edge driven MMD dome midrange
•Unipivot patented rotating allows tweeter to be directed at the listener's location
•Allows Direct connect computer-optimized, voice-matched outboard passive crossover for superb detail & accuracy
•Adjusts Tweeter level on tweeter by simply rotating the tweeter to add or subtract 3 dB output
•Ohm impedance: 2
•Top-mount depth: 3-1/4"
CLARION EQS746 1/2-DIN Graphic EQ/Crossover
Product Specifications:
•7-Band Rotary Equalizer
•12 dB Boost/Cut at 50 Hz, 125 Hz, 345 Hz, 750 Hz, 2.2 KHz, 6 KHz, and 16 kHz
•Auxiliary Input with Source Select Switch
•Adjustable Aux Input Sensitivity
•Subwoofer Output Level Control
•Gold-Plated Preamp Inputs and Outputs
•Rotary Volume Control and Fader
•6-Channel RCA Outputs
•Selectable 60/90 Hz Low-Pass Crossover
•Crossover Slope: 12 dB/octave
•Maximum Output Level: 7V RMS
•Input Sensitivity: 50mV–4V RMS
•Signal-To-Noise Ratio (S/N): 105 dB
•Frequency Response: 10-50,000 Hz
•Total Harmonic Distortion (THD): 0.005 %
•Input Impedance: 10K Ohms
•Output Impedance: 50K Ohms
•Stereo Separation: 82 dB @ 1 kHz
•Dimensions: 7" W x 1" H x 4" D
$100 ship for 60.9
$85 ship for 692.9
$35 ship for EQS 746, $30 if you buy all together
to 48 states
no trade, need cash
60.9CS 6.5"
692.9I 6"x9"
clarion 746
•Sensitivity: 95 dB
•Rubber surround
•2 ohms impedance
•Power Handling:
•Rubber surround
•Ohm impedance: 2
$100 ship for 60.9
$85 ship for 692.9
to 48 states
no trade, need cash
