F/S: BROKEN MA Audio HK-4000D with Bass Knob and Broken LCD! Needs lil' TLC
Sidebinder
Banned
122
FL
Up For Sale is BROKEN M.A. Audio HK-4000D. I NOT selling this Amplifire as a working Amplifier. I sell as Broken Amplifier with NO GUARANTEE, AS IS MAY NEED A REPAIR Amplifier. I don't know if works and I don't know what wrong with it, you'll have to check it out when you get it! I am offering this Amplifier at a wholesome, generous Discounted Pwrice of $275 since it has been availble since 7/20 on here and I'd like to move it.
Good Price, Lotta Powah!
Known Problwem:
LCD Not Working and Broke. Need NEW Digital Dot-Matrix Display piece.
May NEED additional work! AS IS with NO GUARANTEE, YOU BUY!
MA Audio HK4000D 4000W RMS Class X / D Competition Monoblock
4000W Digital Class X Competition Mono Block Amplifier
RMS Power @ 14.4V
1800W x 1 @ 4 Ohm
3600W x 1 @ 2 Ohm
RMS Power @ 17.0V
2000W @ 4 Ohm
4000W @ 2 Ohm
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
2 Ohm Mono Stable
Dimensions: 12.4” W x 2.71” H x 25.86” D
2-Year Manufacturer's Warranty
NO WARRANTY! YOU BUY, AMP HAVE NO WARRANTY. NO GUARANTEE IT WORK OR NO FIX. AS IS AMP, GOOD PRICE. YOU BUY AMP, YOUR AMP. MAKE YOU HAVE A HAPPY FEELINGS, NICE AMP.
$275 FIЯM OBO
$20
AGAIN??FFS //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
I am confused, does it or doesn't it work?
Only works sometimes it sounds like.
No Work! AS IS/NO WORK/BROKE/NON-FUNCTIONING/NEED REPAIR/NEED FIX. No Warranty, No Guarantee it work. You Buy, Your Amp. Not My Probwlem If Not Work For You, Good Pricesen. Two Forty Five Dollar Shipped!
ruv you rong time? 5 dorra?
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
A Link would be very helpful. Id be interested in taking a look at some gear
57
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
Sidebinder
Banned
Sidebinder
FL
ThatChevyGuy
