EQ? Crossover?
David0321
hey guys well im getting all my setup almost done and this is the last thing i need to buy to install everything just wondering what eq or crossover should i get? and the main thing is im going to be running a stock oem radio so i have to eliminate that somehow and power up everything to a eq or something similar...setup is going to be on a 2012 gmc sierra denali consist of 2 13s w5s JLs with a jl 1000/v2 4 imagine i61s powered by jl 300/4v2 optima red top battery for truck and yellow optima for system audiocontrol epicenter concert series and i believe thats it really want all the system to sound clean especially the voice lmk what yall think guys..thanks
A new style Epicenter with built in LOC would be fine off your rear inputs to work for your subs...Im looking at doing the same thing in my new Dodge DART....but you'll still need a LOC or some sort of EQ for your front chs...on your 300/4 Id recomend an EQ of some sort because not a lot of sound adjustment on a factory deck...usually they are limited to BASS and Treble...or in some cases BASS Mid and Treble like on my DART.....
that DQXS is gonna be a great unit except for how are you going to run it considering you're keeping the stock radio? does your stock radio have RCA outs or do you have the ability to locate and create the low level plugs to use the DQXS? how about the DQL-8?
David0321
David0321
houston tx
David0321
michigan born
    May 14, 2026
michigan born
    May 14, 2026
