Epicenter and or DSP ?
  • 4
Sinisterspawn
13
St.louis
I was wanting to add a DSP to my set up . Do I need a DSP and a Epicenter or am I good with one or the other ?
They are 2 different things. An epicenter "restores" bass not in a track and a dsp actually allows you to adjust each speaker connected through it whether it's crossovers, time delay, etc
One more question , should I be using 0 gauge power wire for my set up or stick with the 4 gauge ?
after 40+ years in car audio, I've seen processors develop, peak and dissapear like old gym socks.
the Epicenter was leagues ahead of its time. in Today's world of DSP, if you still have and odd acoustic/pseudo-acoustc "odd hole" in bass and lowest range of the low end, the Epicenter can help. howeve its more of a band-aid than an acoustic fix.
Don't misunderstand I have an early 90's retro build with both the epicenter and the ESP-1 center channel unit as well. Love them both for what they are and how they fit in car audio history.
All that said what are you trying to accomplish or fix? what other amps/equipment are you planning? Whats the overall system goal? Audio control is GREAT stuff. and they have a couple-5 different pieces, including DSP packaged inside a few amps. Might be able to get a 2-fer with more/better amp power and possibly elminate pieces and reach your goal in less footprint.
~Rob
I have mused doing that, but I like keeping my jalopies looking OEM. Now if I knew how to fiberglass like NSTALN, I would have done it long ago.
22
I have a couple questions - Is it worth it to use both the MatrixPlus and the Epicenter ? I wanted to try it but I am having problems with where...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
846
525
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
488
Sinisterspawn
Sinisterspawn
St.louis
R Roby
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
