Engine Noise
  • 2
Glen22
We have had a loud noise that happens when the car/engine is cold for only about 10 seconds, and then goes away. I am not sure if the noise is coming from our speakers, or if it is actually a mechanical problem. It sounds like a loud engine vibration. We bought our car last year, and then later found out it had blown speakers and had tons of wires that were wired to an amp. We got the speakers replaced, and the wiring out, and everything put back to factory, and now are having a loud noise. Like I said, the noise happens only when he engine is cold and happens when it gets around 1400-1800 rpms, and then will last for 10 to 15 seconds and won't happen again until the next time I start the car. I have turned the radio off and the noise still persists. I called the shop where we had our speakers replaced, and they didn't think it was from the speakers. Does this sound like it could possibly be a speaker/wiring issue? I have had the car at the mechanic, and they can't figure out where the problem is coming from. Just trying to figure this out! Thanks.
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
Glen22
Glen22
Chicago, IL
Mobile_Install
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
