Engine Noise/Whine from Pioneer Head Unit
jadyn123
17
Arizona
Installed a Pioneer head unit a week ago. Has been working fine until yesterday when I started the car it made a loud noise. Later when diagnosing the problem I realized the whine varies by engine rpm. I tried different grounds and grounding the rcas. I dot believe I grounded them right however, because it didn't play music loud at all after I did so. I may try again later.
Anyways, the deck makes engine whine with the engine on and a weird popping sounds with it off.
Any ideas what it could be?
Why would it start having this problem after working fine for a week?
Thanks!
Purchased a new RCA cable and it didn't help.
Perhaps I'll try requiring the entire thing, I used the pervious owners wiring.
Should I ground the ground wire from the harness directly to the head unit and then run another wire from the head unit to the chassis/body?
Pioneer is infamous for this problem, I believe it is the pico fuse that blows and causes the noise to come thru. their is a way to solder a resistor in its place to fix the problem, i have seen a few posts online showing the process. i found it easier to just ground the rca's; the most effective way being to ground them to the unit itself. When i grounded the rca's straight to the chasis i still had some noise come thru. I have seen this problem in a number of units and this always solves it.
like mylows said above ground the rca's on the HU. U blew the pico fuse either do that or toss the unit. If u say u already did this plus tried new rca's then well its toss time
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
jadyn123
jadyn123
Arizona
alsa2009
maylar
    Jun 2, 2024
    Jun 1, 2024
