Engine Noise/Whine from Pioneer Head Unit
jadyn123
Installed a Pioneer head unit a week ago. Has been working fine until yesterday when I started the car it made a loud noise. Later when diagnosing the problem I realized the whine varies by engine rpm. I tried different grounds and grounding the rcas. I dot believe I grounded them right however, because it didn't play music loud at all after I did so. I may try again later.
Anyways, the deck makes engine whine with the engine on and a weird popping sounds with it off.
Any ideas what it could be?
Why would it start having this problem after working fine for a week?
Thanks!
Purchased a new RCA cable and it didn't help.
Perhaps I'll try requiring the entire thing, I used the pervious owners wiring.
Should I ground the ground wire from the harness directly to the head unit and then run another wire from the head unit to the chassis/body?
Pioneer is infamous for this problem, I believe it is the pico fuse that blows and causes the noise to come thru. their is a way to solder a resistor in its place to fix the problem, i have seen a few posts online showing the process. i found it easier to just ground the rca's; the most effective way being to ground them to the unit itself. When i grounded the rca's straight to the chasis i still had some noise come thru. I have seen this problem in a number of units and this always solves it.
jadyn123
jadyn123
Arizona
alsa2009
