Enclosure Specifications for AB XFL 12's?
  • 5
I was playing around with this using those dimensions and it looks pretty good. What do you think?
NewSlotPortBox_zps407fb667.jpg'%20alt='NewSlotPortBox_zps407fb667.jpg'>
OK, Scratch that one above... I think the woofer displacement is .4 for those 2 subs so I corrected that and I lengthened the port until I hit 27" which is obviously longer than the box is deep so does that mean my port will need to be 4" wide the whole way (on the side and back) so if the light bulb that just went off in my head is correct then my port boards will be 1@ 12x19.25 and 1@ 12x6.75 in the shape of an L making my port 27" long? Is that how that works?
So this one below....
NewSlotPortBox02_zpsa58a50fd.jpg'%20alt='NewSlotPortBox02_zpsa58a50fd.jpg'>
Unfortunately now the box is only 3.86^ft so I gotta make it deeper, maybe around 28-30" deep?
OK, I changed the Depth to 28" so now it's 13.5x36x28
When I change the port length to 28" then it's tuned to 26Hz
When I change the port length to 15" then it's tuned to 32hz
PortDesign_zpsabc65142.jpg'%20alt='PortDesign_zpsabc65142.jpg'>
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
694
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
FadedSpy
FadedSpy
Sioux City, IA
FadedSpy
    May 16, 2024
    May 16, 2024
