Enclosure Material
fasfocus00
doITdaWHITEwayORdoITtwice
MDF vs Birch
I want to know which one is a more acoustically dead material? which material holds screws better?
only reason I'm asking is b/c i'm about to do a build and I want to use birch to conserve on weight so I don't have to put lowering springs on the front to even it out.
Both are good but I can never seem to find the birch I like ;\ But MDF really aint that heavy.. depending how big of a box your doing.
weight difference wont be much between birch/mdf - homedepot/lowes sells a white wood plywood, for box building just as good as birch 1/2 the price, it is made from a hard word like birch but the finish is not as nice, you are paying for the nice finish on a birch plywood. now if you want save weight, build it out of 1/2 mdf - brace well and coat inside with fiberglass resin. they also make a product out of fiberglass type material, build box and soak with resin, hard as hell and strong & light.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
790
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
4K
fasfocus00
fasfocus00
New Orleans, LA
BassMechkanic
    May 31, 2024
    May 24, 2024
