Enclosure build "single T212D4"
THUMPPER
Pound That Sound
here is some buld pics for an enclosure for
a RF T212D4...built to RF's Powerfull Enclosure
specks (2.25cf3 plus sub,port,corner displacement)
and tuned at 32hz
I hate MDF dust...had a lung infection from the stuff
last spring so I don't take any chances anymore
one of the little tweeks I have been working on....
it will all make sense in the end
no 90* edges..all 45* and will be sanded perfectly smooth
do you only have one wall outlet in the shop?
you must be looking at the rats nest above my head...LOL
the lights and a squirrel cage ******* thru a furnace filter
are plugged in up there as well as the garage door
I got a 600v lead with a 30amp circut breaker running all the saws
hhhhhhfffffffffttttttttttt, pppppppfffffffffffftttttttttt, hhhhhhhhhffffffffffffttttt, pppfffffffffffffftttt,
you are my father.
formaldahide ftmfl
Where did you get that mask by the way? I think I should really invest in one of those. Dust mask and goggles just don't cut it when routing MDF. I also share your dislike of MDF dust.
this is part of my welding gear....
it is the Speedglas Adflo system...the part I am using in the pic
is called the Clear Veiw sheild...I use it as my grinding sheild
at work...it's battery operated and keeps positive preasure inside
the helmut and has a hepa filter and an add on Nosh filter for dealing
with fumes...the welding helmut hooks up in the same way
great in the summer time,it keeps your face cool:D
THUMPPER
Pound That Sound
THUMPPER
Salmon Arm BC Canada
Propimp
