elemental designs
I talked to one of the tech guys he was pretty cool... even told me another sub(FI) would have more output...at a certain wattage...so they arent so bad
Ummm... mandos, are you sure eD uses a tall surround?
sub w/ tall surround...
one more...
I call marketing BS on this one...
Alright, so based on subs with a COMPARATIVE xmax...hell, these subs have LESS xmax than the 13Kv.2 that you posted and less cone area to boot:
RE RE 12:
480 cm² Sd
12mm xmax
JL Audio 12W3V3:
520 cm² Sd
13 mm xmax
13Kv.2:
545cm² Sd
15.1 mm xmax
So, the 13Kv.2 has more cone area than those two subs with a more conventional surround while offering more xmax.
For the subs you show that have the VERY tall surrounds:
Image Dynamics IDMAX:
545 cm² Sd
24.6 mm xmax
TC Sounds TC-3000:
452 cm² Sd(their site lists 240mm diameter = 12 cm radius^2 * PI for that #)
30 mm xmax
I'd certainly hope the drivers that are going to move 9.5+ mm farther one way will have a taller surround.
The IDMAX driver has the same cone area, and more xmax, and it has a much taller surround. That TC driver has less cone area and more xmax.
Granted, it might not quite have the same cone area as what a 13" driver with a conventional cone would be, but it's definitely got more than a conventional 12" driver with an equal xmax.
RE RE 12:
480 cm² Sd
12mm xmax
JL Audio 12W3V3:
520 cm² Sd
13 mm xmax
13Kv.2:
545cm² Sd
15.1 mm xmax
545 cm² Sd
24.6 mm xmax
TC Sounds TC-3000:
30 mm xmax
So by that line of reasoning, the IDMAX (as well as the ID v.3) should be classified as a 13" driver, too.
But then we have a JL driver that use the 13 designation (13W6v2 -- I know, 13.5" technically)... 648 cm² Sd -- actual outside frame dia of 14", vs. 12.375" for eD '13-in.' subs.
So, JL 13" > eD 13" = ID 12" -- if the original (ID) uses the 12" designation, and the rebadge (eD) uses a 13" designation, I would call it marketing BS.
camaroaudio69
B@ngin Loud
camaroaudio69
dowtown near tha lake
Hintzyboy
Mike Mccabe
