Electrical Upgrade: Which one first? High Output Alternator or Batteries.
The correct thing to do first is...
  • I don't know.
    Votes: 0 0.0%
  • Total voters
    10
SmartAsss
Scenario: 1500w+ sound system is causing the lights to dim. Due to a high current demand, voltage drop is happening.
A) Upgrade the factory alternator with a high output model.
B) Add more batteries.
C) I don't know, I'm hoping there are enough intelligent members to make this poll will give me the correct answer.
Im using this for profiling purposes. Lol
Add a second battery first, or upgrade to a better battery up front. No matter how good your alt. is, it will still take time to spin up, and supply proper amperage/voltage.
Hilariously false.
Dimming comes during the voltage drop from the alternator output voltage of around 14.4v to the battery resting voltage of about 12.6v. The only reason the voltage drops is the current drawn is higher than what the alternator can provide. No matter how many batteries are added, the voltage they rest at never increases so they can NEVER stop dimming. Only adding an adequately sized alternator can stop dimming. There are no ifs, ands, or buts. People that say otherwise do not know what they are talking about.
Im not looking for an answer to my own electrical needs, I'm simply seeing how many people understand the basic concepts of a cars electrical system.
ecrack shush, don't give away the answer lol.
Why does adding a battery or replacing the existing one upfront with a larger one stop peoples lights from dimming though?
It never has, hence why you always see people posting threads like, "why are my lights flickering, I have 1-2-3 batteries, etc.."
The lights will stop flickering because their amps draw so much power that the alternator is no longer keeping up at all, the voltage drops to the battery's voltage at that point the battery is supplying a steady stream of the power to the system, lights stop flickering, lights are dim but not flickering, but if you read the voltage you will be looking at a low voltage of 12.6 or less. This would be a voltage drop. this is what we are trying to prevent. It would be akin to just disconnecting the alt, or turning the car off.
Simplified,
When the lights are flickering, its because your alternator is bouncing between its normal 14v+ charging voltage and the battery's 12.6 resting voltage. trying to keep up.
Once the alternator is way out of its league, then the lights stop flickering and you will just have a low voltage situation. Adding another battery only makes the alternator have to put its current into an additional device compounding the problem.
A low voltage situation is hell for the alternators rectifier diodes, and its voltage regulator. because more current is constantly flowing through them. this heats them up, and eventually kills the alternator.
make sense?
SmartAsss
SmartAsss
Buckeye
SmartAsss
