Sa-8 ported enclosure ?
Florida_BOY
THIS IS MY CALCULATIONS....
1.5cu.ft Tuned to 35Hz
Subs will most likely be powered by a POWERBASS SA1000.1D
Subs are DVC 4ohm wired to 1 ohm
This will be in a daily driver, but would like them to get low as they can while still sounding good with Rock as well
.6 @ 35 hz is the recommended enclosure. you're over double that... 1.5 might be ok for 2 SA8s. But Sundown suggests no larger than .6 for any amount of power.
Yeah, he's going with 2 8's. That 1.5 will work, but careful on the amount of power you put to them.
I got that after rereading the original post...but its still on the large side. Possible get away with it on RMS power. But it has been said many times by the owner no larger than .6 is recommended.
Yes, the question is...
Is this enclosure too big/small for (2) SA-8 subs with 1000 watts powering them.
Would anyone recommend a higher/lower tuned enclosure?
Perhaps you should go to the Sundown site and read...Jacob recommends 0.6 to 1.1 ported per driver.
With that said, 1.5 should be perfect for a pair of them.
Florida_BOY
Florida_BOY
Florida
Florida_BOY
BP1Fanatic
BP1Fanatic
