Electrical upgrade help???
  • 2
trenthonda1
Florida
i have a 99 f150 all the electrical is stock. i wanna run a Autotek Mean Mechine 4000d.1 to my AudioQue hdc3 15. i wanna wire it a 2 ohms. what electrical upgrades do i need for this amp to preform well.
* 4 ohms: 1000 watts x 1 chan.
* 2 ohms: 2000 watts x 1 chan.
* 1 ohm: 4000 watts x 1 chan.
Ps is there a better amp for around the same price (200) that would do the job?
given the age of the vehicle, i'd do the gambit -
H.O. alt
New AGM battery (starting)
Big 3 (1/0)
go over all of the stock electrical wiring for the alt and fuse box and battery and re-terminate as necessary.
a secondary AGM battery may also be nice, but you don't want it behind you in a truck.
batteries should be in enclosures vented to outdoors. even sealed AGM batteries off-gas a little bit and shouldn't be located in the cabin unless you weld a battery box for it and vent it out. it can be a lethal projectile in an accident, battery acid in the cabin would be bad news, and the fumes would make you sick.
sure, people put batteries in the cabin with them. but some people also smoke crack. so who cares what other people do?
anything in the cabin with you should be secured enough to withstand an accident at highway speeds. and given the risks, i don't think it's worth it. a battery box in the bed would be a better idea - but that brings another set of issues with routing cables.
Yea im mostly likely going to go that route. Dont plan on winning competitions or playing full tilt all the time. I watched some good videos last...
10
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
trenthonda1
trenthonda1
Florida
keep_hope_alive
    May 18, 2024
    May 18, 2024
