Electrical upgrade and amp question
Perversion
I've got a 2 part question here.
First off, I just bought 2 12' Alpine Type X, and I'm trying to find a decent amplifier to run them. I'm kind of set on Hifonics and have been told that the Brutus 2400 is a good choice. I'd imagine its overrated, power wise, but have been told its close. I plan on running these subs at 2ohms and do not want a lot of overkill power. Again, I'm set on Hifonics. There's a 2200w, a 2400w, and a 3000w. Wondering which one fits best? Please toss me advice.
Secondly, the amount of power I'm about to push I'm sure demands an electrical upgrade. I plan on the Big 3 for sure. But I'm guessing I need to be in the market for a second battery. People tell me to get a Kinetik, and I'm wondering what size I need to comfortably run these subs on the amp were discussing. Hopefully, I won't need another alternator, and a battery will work fine. But if kinetik will do the trick, I REALLY NEED HELP with what size to get.
So, I'm thinking the brutus2400w at 2ohm with whatever size kinetik is most suggested. Please help
the subs are dvc 4ohms, but ill wire them to a 2ohm load. the stock alternator isnt worth mentioning....its a 1997 dodge Avenger
the opinions ive been getting on power supply has differed too much to make a solid decision. some people say that if i do The Big 3, and buy a very nice big battery, a 2400w amp wont be too much to handle. others say just add a kinetik, and others say another alternator. in a perefect world, the big 3 and a nice fat battery is how id like to do it, but i have a bad feeling lol.
and would taking them down to 1 ohm require a different power supply?
i cant decide which would be better for me. they say type x SQ is fantastic, even at 1ohm. im a fan of the initial "Hit" of the bass more than the long basslines. id much rather feel the punch, if you know what i mean.
Your battery is stock right? If so, you're going to want a new battery anyway. So what I would do is buy the battery, do the big 3, and buy a voltage meter. See what voltages you are hitting and dropping down to. If you listen to it loud a lot, doesn't matter how big that single battery is, your stock alternator isn't going to be able to recharge it. But if you listen moderately, you might be fine with just a new battery, which you want anyway. So get the battery, watch voltages, and then if you are dropping too much, turn it down until you can afford a bigger alternator.
Just what I would do.
Edit: That's for the two smaller amps. For the 3kW, you're pretty much staring a bigger alternator right in the face.
So getting 2 smaller amps is the way to go? And if that's the case, would I need a second alternator? Or just a nice new big battery? And what size amps would I get? 2 1250w-ish?? Or is 4ohm acceptable?.... God, I'm waaaay out of my knowledge comfort zone here..
So u recommend running 1 amp at 1 ohm on the 2500 u mentioned? That's sounds good to me! And what specs am I looking for in a battery and alt? I want to be able to COMFORTABLY handle up to 4k watts and eliminate dimming...
Perversion
Perversion
St. Louis, MO
dunerider650
