Electrical System
stock alt on cavaliers is only 105A, and that amp draws over 100A at full power.. and i realize that he wont be playin at full power all the time, but sometimes he will, then what??
90 amp alt here. batt up front. and optima yellow 31 in the back. big 3 done. with a 50amp amplifier and 120amp amplifier. guess im screwed //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Is that in your jeep? Mine's got a 117a from the factory //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
So if i get one battery it should b ok??????
i honestly doubt your even going to need an extra batt. but if ya wanna be safe and dont wanna spend much jus get a cheap deep cell at walmart and install it in the trunk //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if you have more of a budget. a Optima yellowtop group 31 would be a good buy
lucky SOB //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
but i thought no matter how many batts you have the alt can still on put out 105A.
yup your right. but you have 2 batteries with "amps" that can be given out to the electrical system. jus make sure you do the big 3 also //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ooo.. so the alt 105A isnt the max that can be put out.
Yes, it is. However having two batteries is like filling two buckets of water (instead of 1) and drawing a little from both. You will have more amperage at your disposal to run your car AND your system should you want to crank it and up the amperage draw.
bgbllr22489
bgbllr22489
westville, IL
lukeduke28
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
