loopkiller 10+ year member
PERMA-BANED
99% sure this is a bad alt. All of the major parts stores like Autozone, Checkers, Napa, and others test your alt for free.
http://catalog2.genpt.com/catviewer15/(zmljtu45byel1dizjvbbhz55)/Catalog/Detail.aspx?ShowPics=1&R=NBP7558_0222631311what kinda car is it? what batt size is it? everstart maxx batts are pretty good and inexpensive from walmart. you dont need to take the alt out to test it. im sure the alt is fine and its just the battery.
Also - when I first jumped the battery I ran the car and got gas so I drove about a mile as well although I didn't run anything. I'm going to try running stuff to actually charge it but I've never had to do that before. Right now I'm having a tough time even trying to jump it again off my battery booster.you dont have an actual battery charger? When you let it idle turn **** on in the car, most cars just letting it sit and idle wont charge the battery, its just enough to run the car.
they have a machine inside to do bench test, it has a motor with a pulley and they put a belt on it and spin it at certain speedsyeah, they take the testing equipment out to the car, you wont take the stuff in. plus how would a alt function with no belts turning it
oh, when they tested an alt for me once they took a machine out to my truckthey have a machine inside to do bench test, it has a motor with a pulley and they put a belt on it and spin it at certain speeds
11.19V= bad battery, 13.8V running= good alt and voltage reg. Get a new battery.update:
jumpstarted car - battery runs around 13.5-13.8V while idling
I had car running with no system on for almost an hour.
I turn off the car - and try to turn it back on right away - nothing but the solenoid click.
The dashboard lights come on and I can run my headlights but but the engine doesn't turn over at all.
Battery -> 11.19V
Diagnosis?
